Hello.
Here you can see property boundaries, from which I would like to create surfaces, but since every line I connect only appears once, only a closed polygon is created, resulting in only one surface. I would like to solve this problem so that there are three separate surfaces next to each other, bordered by the property boundaries. How could I easily resolve this issue?
Hi @szekeressz you could try polycurve.closed loops from ampersand
Thank you, @sovitek for the helpful response. It partially does what I want. It finds the three surfaces, but not the one I want. The red and yellow surfaces turned out fine, but the cyan one did not because it became a surface covering the entire area.
could you share you rvt ?
Sure.
REVIT.rvt (5.3 MB)
1hrsz.dwg (492.2 KB)
Project_topo.dyn (52.6 KB)
Hi @szekeressz probably something here could work
