Hello eveyone,
I want to create a width dimension for each wall in my current view
First, I create lines of the middle section of each wall thanks to the vectors tools
Secondly, I want to use the “Dimension.ByElements” node with my walls and these lines but it fails.
Here is my dynamo :
It seems that the “Dimension.ByElements” node is not the good choice to do what I want : “ReferenceElements” requests two elements like the interior and exterior faces of each wall but it doesn’t fit. I tried without success.
Can you help me please ?
Best regards.
Hi @City_Hunter87,
This will be easier with the Dimension ByReferences node in Genius Loci package and the references nodes.
Hi @Alban_de_Chasteigner
Thanks a lot for your answer and your package. It is very helpful.
I tried to use your packages without success however I created lines to do my dimensions lines and I get each reference of wall’s side.
I guess I don’t use properly “Dimension ByReferences” Node
Can you explain me where am I wrong with your nodes please?
Thanks a lot
Hi Julien,
You missed the longest lacing on the Dimension ByReferences node.
Dimension walls.dyn (23.4 KB)
Thanks @Alban_de_Chasteigner ! I was so close lol
Again, thanks for your package and your help !
Have a good day !
