Hello
I tried to create a shared parameter script but the end result is null.
Thank you
paramétres partagées.xlsx (15.7 KB)
Create Shared Parameters from Excel .dyn (22.4 KB)
Hello
Thank you
Hi Rahmeni,
Please read the following post How to get help on the Dynamo forums
There are know issues with Excel and Dynamo try the alternative Data.OpenXMLImportExcel node (see also here)
Screenshots with information pinned also assists the forum members understand your problem
Also I would look for a Revit add in to transfer shared parameters if that is your intent
Onto your graph…
The list clean / transpose breaks the information - you will need to fix the Excel
Looking at the Excel
Repeated names will possibly create multiple shared parameters with different GUIDs
Fix the blanks
Remove the header (Row 1 in Excel)
This will not work
Make sure your group names are in the current shared parameter file
Thanks so much
