Hi
I have a polycurve (non-closed). What i want to do is create some points along this curve, where I am sure that the distance between these points (in space) is exactly X.
The idea is that I can not use Curve.PointsAtSegmentLength because if the curve is BENT, then the distance in space between these points is less than X.
My idea was as follows: (For X, let’s take 4)
I want to create a sphere at the startpoint of the polycurve, with diameter X=4.
At the point where the sphere intersects the curve, i want to create a second point.
(Actually this is done by using Geometry.Intersect between the polycurve and the sphere, which returns a curve, so I need to get the endpoint of the returned curve to continue.)
At the returned endpoint I want to create a second sphere, and so on.
I want to repeat this process until I have reached the end of the curve.
I have ‘hardcoded’ the first two steps of this process with nodes. I think I would like to re-write this to a CodeBlock with a for-loop. BUT I don’t know how to do this. Could anyone help me with this?
Any (good) other algo-ideas are also welcome
Cheers
