Hi people on the Dynamo forum,
First of all, Sorry for my bad english, because it’s not my native language. I’m trying to create a filter and visibility graphic override by filter rules from an Excel file in Dynamo / Revit with Python.
Thanks to Ben_Osborne, Konrad_K_Sobon and David Dória
At this moment my Dynamo script creates the filter and overrides the visibility graphics in Revit for 1 Excel imported row of data. Now I would like to make some kind of `for loop’ in python to create multiple filter elements and visibility graphic overrides by multiple rows of data in Excel for a specific view in Revit.
My idea of achieving this: I changed my Excel file from 1 row to 2 rows of data and manipulated my Dynamo nodes and my python code in a way I thought it should have worked, but an Error occurs. The error is pritty straight forward, because the inputs, which were strings in the 1 row of data script', became a list of two strings in
the 2 rows data script’.
I know, by `hard coding’ of the indexes of the inputs in the script I can make the script work for multiple filters and visibility overrides, but I would like to have the computer to run the code by itself. Because in the end I would like to make 100 filters and overrides.
My inputs in the Python script are the strings and doubles from Excel.
Here is my dynamo script:
Python-script-Filters.dyn (225.1 KB)
This is the python code for one filter and visibility override for 1 row of Excel data:
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import System
from System import Array
clr.AddReference("RevitAPI")
app = uiapp.Application
### Gets the active document your working in
### INputs
view = IN[0]
filter_name = IN[1]
catlist = IN[2]
pattern_name = IN[3]
foreColor = IN[4]
transparency = IN[5]
### Create INput - IN[0] - Categories for BIM-Protocol row
catName = []
for cat in catlist:
catName.append(Revit.Elements.Category.ByName(cat))
# Revit Categories
cats = UnwrapElement(catName)
cat_id = []
for catid in cats:
cat_id.append(catid.Id)
# Revit Categorie Id's
cat_ids_list = List[ElementId](cat_id)
### Create INput - IN[2]
# Create fill pattern - <Solid fill>
target = FillPatternTarget.Drafting
orientation = FillPatternHostOrientation.ToView
pattern = FillPattern(pattern_name, target, orientation)
# Create fill pattern element - <Solid fill>
fpelement = FillPatternElement.Create(doc, pattern)
### Create INput - IN[0] - Filter element
# Get Built-in Parameters
pWorkSet=ParameterValueProvider(ElementId(BuiltInParameter.ELEM_PARTITION_PARAM))
pFamType=ParameterValueProvider(ElementId(BuiltInParameter.SYMBOL_NAME_PARAM))
# Create Filter rules
xWorkS=FilterStringRule(pWorkSet,FilterStringEquals(),"BL_New_Structural",False)
xFamT=FilterStringRule(pFamType,FilterStringContains(),"2",False)
# Create operators within the filter rule
filt1=[]
filt1.Add(ElementParameterFilter(xWorkS))
filt1.Add(ElementParameterFilter(xFamT))
icolfilt1=List[ElementFilter](filt1)
andfilt1=LogicalAndFilter(icolfilt1)
# Create filter and convert to an element in Revit
pfeelem=ParameterFilterElement.Create(doc,filter_name, cat_ids_list, andfilt1)
### Avoid instance INput problem
if isinstance(pfeelem, list):
pfeelem = pfeelem
else: pfeelem = [pfeelem]
if isinstance(view, list):
view = view
else: view = [view]
if isinstance(fpelement, list):
fpelement = fpelement
else: fpelement = [fpelement]
if isinstance(foreColor, list):
foreColor = foreColor
else: foreColor = [foreColor]
if isinstance(transparency, list):
transparency = transparency
else: transparency = [transparency]
### Function
def ToRevitColor(dynamoColor):
return Color(dynamoColor.Red, dynamoColor.Green, dynamoColor.Blue)
### Overriding graphic settings
try:
for v, filt, fP, fC, ts in zip(view, pfeelem, fpelement, foreColor, transparency):
over = OverrideGraphicSettings()
over.SetSurfaceForegroundPatternId(UnwrapElement(fP).Id)
over.SetSurfaceForegroundPatternColor(ToRevitColor(fC))
over.SetSurfaceTransparency(ts)
v = UnwrapElement(v)
v.SetFilterOverrides(UnwrapElement(filt).Id, over)
OUT = "Graphics overriden!"
except:
OUT = "Oops! Something went wrong"
