I would like to create two mesh for my two rooms. Hence, the first step I did is to create two PolyCurves, according to room finishing boundaries. Then, I want to get mesh for each surface, so I think I should create topography for two surfaces first. Am I right? Or is there any way more straightforward?
Please forgive my messy scripts, I tried to test many methods to achieve it. But failed.
Thanks for your reply!
It’s quite helpful. I would like to a fire evacuation route from the middle point of flat entrance doors to the middle point of communal doors. Hence, I want the route could be straight rather than curves because I need to get the distance to compare with the regulation. From my perspective, the start point could follow the point on the mesh to the end point.
I saw some posts on forum, but none of them use nodes to draw straight routes.
I knew it. It would be better for me to create nodes for my company cause they only need fire evacuation route and all of fire drawings I will do it in Dynamo. But anyway, thanks for your suggestions.
