Create lines connecting each point from a list
Hi everyone, I am a beginner of dynamo.
I would like to ask how should I create lines that connect all the points in the same list one by one.
Should it be line from start and end point, but how should i split up the points one by one.
Here is my progress and my excel. Thank you for your help.
This is the excel
Polycurve.ByPoints node will do the trick.
Thank you for your advice.
However, it automatically connected all the points within the list.
My expected outcome are 1 to 3 or 4 to 10, something like that.
If do so, should i use totally another methods?
Not sure what you mean. List manipulation, but what manipulation isn’t clear. Do you mean point 1 to all of the other points, point 2 to all of the other points, etc?
@eldwinma79 Are you trying to pair points by proximity to create a line or creating a line through the all points based on the next closest neighbour?
Worth a look here for some tips on the last workflow.
