Create Group of intersecting solids
Hi :slight_smile:
I´ve got a number of interesecting solids and wish to group them (put them in different lists).
I have to use the Geometry.DoesInteresect Node instead of the Bimorph interesection nodes, these solids are “virtual” and I don´t want to create DirectShapes to be able to use the Bimorph Element Element Intersection.
As a result of 10 objects I get a list of true and false values.
The list looks something like this (0 = False and 1 = True):
L0 = 1 0 0 0 0 1 0 0 0 0
L1 = 0 1 0 0 1 0 0 0 0 0
L2 = 0 0 1 1 0 0 0 0 0 0
L3 = 0 0 1 1 1 0 0 0 0 0
L4 = 0 0 0 1 1 0 0 0 0 1
Every objects interesects with itself (of course), but my goal is to group all objects which are “somehow” in relation to each other.
If object 3 and 4 intersect each other I wish to group them with the object 10, which collides with object 4.
Does anyone have an idea how to properly “solve” this problem :wink:
Thanks and kind regards,
Jannis
Here’s a solution using Python to determine the sets of intersections. I think that doing it with OOTB nodes alone is tricky because of the potential levels of nesting required to establish the groups
# Adapted from https://stackoverflow.com/a/4842897/8091631
intersections = IN[0]
out = []
while len(intersections) > 0:
	first, rest = intersections[0], intersections[1:]
	first = set(first)
	lf = -1
	while len(first) > lf:
		lf = len(first)
		rest2 = []
		for r in rest:
			if len(first.intersection(set(r))) > 0:
				first |= set(r)
				rest2.append(r)
		rest = rest2
	out.append(first)
	intersections = rest
OUT = out
You can simplify your inputs into Geometry.DoesIntersect by using cross-product lacing, instead of List.OfRepeatedItem
41965_Python.dyn (25.3 KB)
Hope this helps,
Thomas
Thanks a lot :wink: This works great!! Exactly what I was looking for :slight_smile:
Thomas,
Thank you!! :smiley:
Hi Thomas,
Thank you for the python code. I use it in one of my scripts.
Since i am new to python I have a additional question. Could you add another level to the script?
The input cubes in the example above is a flat list. However I have a script where i start with a three level list.
The expample below shows that I got the surfaces from walls, one of the walls is divided into two ‘solids’. This is why i have a three layer list.
I want to group the wall surfaces based on their intersection (in their own list, not to a flat list of all the wall surfaces) to later create a ‘cell’ with Topologic.
Kind Regards,
Martin
Hi, @MartinVrielink
Share rvt and dyn files, please.
And try:
Hi Vladimir,
Thank you for your response and solution. I really appreciate it.
Sometimes the answer is so simple and is almost before your eyes.
Kind Regards,
Martin
