Hey guys I need your help!
I want to transform this DesignScript-Node into a Python-Node but I can’t get the needed face(s) for NewFamilyInstance Method (Face, XYZ, XYZ, FamilySymbol). This is what the DesignScript-Node looks like:
I tried it with the faces of an extrusion but the faces have no reference:
app = uiapp.Application;
#create
cp = Autodesk.DesignScript.Geometry.Point.ByCoordinates(0, 0, 0)
r = 1
circle = Circle.ByCenterPointRadius(cp, r)
c_rv = gp.ProtoToRevitCurve.ToRevitType(circle)
lines = List[Curve]()
tess = c_rv.Tessellate()
for i in range(len(tess)-1):
if i == len(tess)-1:
l = Line.CreateBound(tess[i], tess[0])
l = Line.CreateBound(tess[i], tess[i+1])
lines.Add(l)
id_c = ElementId(BuiltInCategory.OST_GenericModel)
shape = [CurveLoop.Create(lines)]
solid_opt = SolidOptions(ElementId.InvalidElementId, ElementId.InvalidElementId)
extrusion = GeometryCreationUtilities.CreateExtrusionGeometry(List[CurveLoop](shape),XYZ.BasisZ,10,solid_opt)
ds = DirectShape.CreateElement(doc, id_c)
faces = extrusion.Faces
face = faces[1].Reference
familytypes = FilteredElementCollector(doc).OfClass(FamilySymbol)
relevantFams = []
for f in familytypes:
if "5dtb-Anker" in f.FamilyName:
relevantFams.append(f)
anchor_fam_symbol = relevantFams[0]
test = Autodesk.Revit.Creation.FamilyInstanceCreationData(face, XYZ(0, 0, 0), XYZ(0, 0, 1), anchor_fam_symbol)
OUT = test
I just need the face of a circle area on which the anchors (anchors on retain walls) are created. Is there a way to create a solid, where I can the faces of?
