Hi All,
Continuing on with my ongoing quest to have a routine which automatically dimensions a square 3D face, I’ve written some code which allows the user to select a face, it then obtains the PlanarFace and its face Edges.
This works fine. It should be a case of obtaining the References to the edges which I’ll then use to create a dimension.
Luckily the Edge Class contains a Property called ‘Reference’ which returns a stable reference to the edge - perfect!
The problem is that when I call this, it returns Null, and I can’t work out why I don’t get a Reference.
Here’s the code:
# Dynamo
clr.AddReference('RevitAPI')
app = uiapp.Application
dataEnteringNode = IN
selobject = UnwrapElement(IN[0]) # Object to select
#Get user to pick a face
selob = uidoc.Selection.PickObject(Selection.ObjectType.PointOnElement, "Pick something now")
#Get Id of element thats picked
selobid = selob.ElementId
#Get element thats picked
getob = doc.GetElement(selobid)
#Get face thats picked
getface = getob.GetGeometryObjectFromReference(selob)
#Get edges of face (returns a list the first object is the list of edges)
edgeloops = getface.EdgeLoops
#Select the first edge
dimedge1 = edgeloops[0][0]
#Select the third edge (the one opposite the first)
dimedge2 = edgeloops[0][2]
#Obtain a reference of the first edge
edgeref1 = dimedge1.Reference
#Obtain a reference of the thord edge
edgeref2 = dimedge2.Reference
OUT = [selob, selobid, getob, getface, edgeloops, dimedge1, dimedge2, edgeref1, edgeref2]
I’d appreciate some advise on why I can’t obtain a Reference?
Thanks.
