Create dataframe of all the parameters of an instance
How to get parameters from an instance… here my try based on the book beyond dynamo…
clr.AddReference('RevitAPI')
clr.AddReference('System')
def parametersDataFrame(document,category):
	elems = FilteredElementCollector(document).OfCategory(category).WhereElementIsNotElementType()
	if list(elems):
		par = [x.Parameters for x in elems]
		params = [[x for x in y if x.AsElementId().IntegerValue != category] for y in par]
		paramNames = [[x.Definition.Name for x in y] for y in params]
		header = paramNames[0]
		d = {}
		for x in header:
			d[x] = list()
		for pg,ng in zip(params, paramNames):
			for p,n in zip(pg,ng):
				d[n].append(p)
		df = pd.DataFrame(d, columns = header)
		df["Instances"] = list(elems)
		df["Element Names"] = [x.Name for x in elems]
		df["Types"] = [doc.GetElement(x.GetTypeId()) for x in elems]
		df["Item"] = [doc.GetElement(x.GetTypeId()).get_Parameter(BuiltInParameter.UNIFORMAT_CODE) for x in elems]
		return df
		return "No instances of this category exist"
instance = UnwrapElement(IN[0])
snoop = parametersDataFrame(doc, instance)
OUT = snoop
which input do i need ?
KR
Andreas
The code is built to take a category as an input, not an element.
To just get the parameters from an element, use element.Parameters. The result will be a list, but if you take one item out and get the documentation, and members directory of the object you should have a good clue on where to go from there.
@jacob.small ,
my scipt runs… there one variable, which i am not able to identify :frowning:
KR
Andreas
Can you post a screenshot of the code?
	if list(elems):
		d = {}
		for x in header:
			d[x] = list()
				d[n].append(p)
		return df
cat = IN[0]
snoop = parametersDataFrame(doc, cat)
OUT = snoop
KR
Andreas
You are calling the variable pd, but it hasn’t been defined anywhere. What are you expecting the pd object to be?
@jacob.small ,
thats the question
i think it is a syntex error in the book, the variable is part of the function(def).
is it global variabl ?
what does a “dataframe” do? … the call it “panda DataFrame”
https://pandas.pydata.org/docs/reference/api/pandas.DataFrame.html
in the book it is part of the chapter 2.2. accessing familyparameters
@jacob.small ,
is this a way? or is the solution in my Code?
hmmm…
KR
Andreas
It may be that you need to import pandas (and likely numpy and perhaps others) using a particular alias (ie: pd).
@jacob.small ,
i found it it is pandas ! how to import this library ?
KR
Andreas
You need to use CPython3 or IronPython3.
See this link for how to customize: Customizing Dynamo's Python 3 installation · DynamoDS/Dynamo Wiki · GitHub
Hello, you can look at this subject
and even more contributions on his blog dated June 25, thanks to Mr. Poupin.
Cordially
christian.stan
if you use IronPython (2 or 3) it is better to use DataTables (Microsoft)
if you use CPython3 it is better to use DataFrame (Pandas)
In the future, IronPython3 should integrate the compatibility of packages written in C like numpy or pandas (via IronClad lib)
my last article about this, use the translation widget (thanks @christian.stan for mention)
@c.poupin @christian.stan @jacob.small ,
None of these codes works…
i think i will need some foldermanagement…
hi, it works, weird
you wouldn’t have made a mistake on the way
Python script
import sys
import os
localapp = os.getenv(r'LOCALAPPDATA')
sys.path.append(os.path.join(localapp, r'python-3.9.12-embed-amd64\Lib\site-packages'))
import numpy as np
import pandas as pd
clr.AddReference('System.Drawing')
clr.AddReference('System.Windows.Forms')
import System.Drawing
import System.Windows.Forms
from System.Drawing import *
from System.Windows.Forms import *
class Form_df(Form):
    def __init__(self, df):
        self.df = df
        self._html = df.to_html()
        self.InitializeComponent()
    def InitializeComponent(self):
        self._webBrowser1 = System.Windows.Forms.WebBrowser()
        self.SuspendLayout()
        # webBrowser1
        self._webBrowser1.Anchor = System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Bottom | System.Windows.Forms.AnchorStyles.Left | System.Windows.Forms.AnchorStyles.Right
        self._webBrowser1.Dock = System.Windows.Forms.DockStyle.Fill
        self._webBrowser1.Location = System.Drawing.Point(0, 0)
        self._webBrowser1.MinimumSize = System.Drawing.Size(20, 20)
        self._webBrowser1.Name = "webBrowser1"
        self._webBrowser1.DocumentText  = self._html
        self._webBrowser1.Size = System.Drawing.Size(678, 378)
        self._webBrowser1.TabIndex = 0
        # Form_df
        self.ClientSize = System.Drawing.Size(678, 378)
        self.Controls.Add(self._webBrowser1)
        self.Name = "Form14"
        self.Text = "Modes constructifs et volume et Id"
        self.ResumeLayout(False)
all_walls = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Walls).WhereElementIsNotElementType().ToElements()
data ={}
data["Modes constructifs"] = [x.LookupParameter("Commentaires").AsString() for x in all_walls]
data["Vol."] = [round(x.LookupParameter("Volume").AsDouble()*0.3048**3,3) for x in all_walls]
data["N°Id"] = [str(x.Id) for x in all_walls]
df = pd.DataFrame.from_dict(data)
a=Form_df(df)
a.Show()
OUT = repr(df),df.to_numpy()
cordially
christian.stan
@christian.stan ,
i still struggle with cmd
get-pip.py file and locating my lib :frowning:
you followed the wiki posted by Mr. Jacob, you managed to install pip in Local and not roaming as seen on one of your captures
cordially
christian.stan
@christian.stan ,
yes i did, i almost there
there are some parts different, the easy installationfiles are missing
the guide said i can ignore these errors…
try ...amd64>.\Scripts\pip install numpy
with point .
cordially
christian.stan
there is still trouble
have i to close revit ?
pip is defnitly here !!
