Hi Eric and Kulkul,
Thanks a lot for your responses.
@erfajo Your workflow uses a lot of nodes that i haven’t used before, so it wil take some time to figure out what they all do (but i do want to know, and learn).
For now the solution by @Kulkul definitely pointed me in the right direction.
Two questions left.
- Does your method to define the (rotation)axis, always create a line in the length direction of the element?
- I will need some help manipulating the list of angles, should i start a new topic for that?
First list:
If angle = 0,90, 180, 270, 360 degrees, replace by 0.
If angle has another value then the above, replace by the negative equivalent (45 to -45).
Second list:
If angle has another value then the above, leave it as it is.
Create Cuboid_v04.dyn (18.3 KB)
Thanks again,
Mark
