Does anyone know how to create beam system ? i didn’t find any node or any other method.
i think i can do rest of part but didn’t find method which can create beam system like we can create floor.
also i am not good in python.
Regards
Regards
This will be the method, I’ll have a play with it later on next week and if it works I’ll chuck it in Crumple…
It looks similar to making a floor, but instead of a curveloop it uses a List (made via the system method versus appending).
https://www.revitapidocs.com/2015/320f188f-5b0e-e34f-0dc1-c652029be9ae.htm
Hardest part will likely be mapping the selected line to an int for the framing loop. This might be a bit more useful as it has the XYZ for direction instead: Create Method (Document, IList(Curve), SketchPlane, XYZ, Boolean)
Curious to know how one will set the beam type, spacing, and the rest. May require two transactions.
