If any package or scripts available for placing beam…
StructuralFraming.BeamByCurve
Thank you so much for your reply…
Beam type and Beam size also changing… Using StructuralFraming.BeamByCurve it is possible…?
Yes, with other nodes and inputs you can grab the right family type, which will also change the size.
Sorry i a m not expect in this. i am very basic learning now. I tried to create first beam from autocad. So i create this script. But result was very bad. If u don’t mind, please help me for this script.
You need to pull the center line of the beam, not all of it’s edges.
Thank you… Is it any possible way to create from beam outer line, like picking edge. because in that video he doing like that… so any nodes is there for that… sorry i am in learning stage, i am also trying but i did not get…
Structural Beam default geometric position is “y Justification : Left” . After i run the script beams are placed outside and then ,i manuelly changed y justification. How can i set default justification to center?
Not sure, and this topic is 3+ years old. Can you start a new topic with a graph, data set, and illustration showing where the problem you’re having is?
sure
