Hello guys.
It’s the first time that I use Dynamo for Revit.
I should create a grid of point on wall in Revit, and I want combine a points of Revit with a text or an excell file.
It is possibile? Can you racommend me the right way?
Thanks.
Could you show some of your work? Thanks.
@Fedeb Difficult to direct you as your destination is unclear.
See if this helps…
This node may also be helpful:
or:
