Corner points rotated scope box
Dear Specialists,
I have an rotated scope box, see picture below.
I would like to receive the corner points of the scope box.
But the transform failed in my script. Could anyone help me?
My knowledge about the RevitAPI methodes/attributes in scope boxes/boundingboxes/transform is low. So extra explanation is helpfull!
Thanks in advance!!
# Add references to the Revit, Revit Services and TransactionManager
clr.AddReference('RevitAPI')
from datetime import datetime
#receive Revit Document
#get
scope_box = UnwrapElement([IN[0]])
elem_ref = UnwrapElement([IN[1]])
#receive orientation object
elem_loc = [a.Location.Curve for a in elem_ref]
begin = [a.GetEndPoint(0) for a in elem_loc]
end = [a.GetEndPoint(1) for a in elem_loc]
points = []
for a in range(len(scope_box)):
    bbox = scope_box[a].get_BoundingBox(None)
    transform = bbox.get_Transform()
    min_pt = bbox.Min
    max_pt = bbox.Max
    corner1 = XYZ(min_pt.X, min_pt.Y, min_pt.Z)
    corner2 = XYZ(max_pt.X, min_pt.Y, min_pt.Z)
    corner3 = XYZ(max_pt.X, max_pt.Y, min_pt.Z)
    corner4 = XYZ(min_pt.X, max_pt.Y, min_pt.Z)
    corner1_transformed = transform.OfPoint(corner1).ToPoint()
    corner2_transformed = transform.OfPoint(corner2).ToPoint()
    corner3_transformed = transform.OfPoint(corner3).ToPoint()
    corner4_transformed = transform.OfPoint(corner4).ToPoint()
    points.append([corner1_transformed, corner2_transformed, corner3_transformed, corner4_transformed])
OUT = points
Hi @rlandkroon not sure is it something here ?
Tnx! I am working with Python. I would like to not use packages.
Do you have ideas in Python? I can also look in the node you sent!
that node is from spring and made in design script :wink:
Yes, but I would like to receive it pure Revit API
What have you tried so far?
I have a copple of questions:
  • I am working with get_Geometry, but this is old API of Revit. Is this a problem?
  • Is there a newer way to receive Geometry information?
  • Does this methode work for every geometry element in Revit?
points = []
    geometry = scope_box[a].get_Geometry(Options())
    #points.append(geometry)
    for geom in geometry:
        if isinstance(geom, Line):
            begin = geom.GetEndPoint(0)
            end = geom.GetEndPoint(1)
            points.append(begin)
Arhhh OK you can try as here in 24…but guess it will work in older as well
forum Home.dyn (4.3 KB)
