Copying schedules from other project
Is there a way to switch dynamo between two running projects. So that I can copy schedules. Basically they are views so but we also know dynamo runs on the active document(project) how can we switch between?
Did you already try Insert/Insert from file/Insert views from file? Within the revit environment
Oh, how did i miss that. Thanks for that!
Is it possible for this process with dynamo while you need to background open files and copy schedules in these files?
I need your help, please!
