Copy only a part of parameter to another
Hello
I am trying to copy only the first few digits of a parameter to another. I have had most succes with String.Remove, but i can’t get the count to default to removing all characters from the given startindex. I can’t use a static value for count as it varies in character length.
If i choose 21 it works only on accesories that have 21 characters after 3
Correct:
Incorrect:
I can’t just pick a high number as that just gives an error of “Count out of range”
Does anyone have a suggestion on what i can do here?
Hello could you show your nodes expanded, probably you need count your characters first
I figured out a solution.
Putting “Count” to null seems to have fixed it so that it removes all characters after 3.
