Copy multiple files from one folder to another
Hi…Is there a node available to copy the files contained in a folder into another folder ?
Thanks erfajo… I had done a search but only found the directory.copy node.
Will this allow just one file to be copied or all the files contained in a folder ?
OK… Back to my original question then… Does anyone know if there is a node to allow me to copy all files within a folder into another folder ?
Apologies if I’m not using the best tools for the job but programming is not my forte, I am just trying to improve a dynamo graph I have written, with the aim of making a specific document issuing process easier.
Dean, it is possible, see picture below
Also find dynamo definition to test it out :slight_smile:CopyFiles.dyn (5.7 KB)
Directory.Copy allows you to copy a folder (and all contents) to another location.
Thanks alvpickmans…worked perfectly.
