Copy Elements from Linked Revit File Failure
I am trying to copy Floors from Linked Revit File.
I get a warning as below:
File “”, line 28, in
Exception: Copying one or more elements failed.
The overall operation fails because of a few elements. Please tell me how I could ignore these exceptions as the operation runs as a set of elements to be copied.
Python Script as below:
import clr,System
clr.AddReference(“RevitAPI”)
current document
input link document
linkdoc = UnwrapElement(IN[0])
#collect levels from the link document
collector = FilteredElementCollector(linkdoc).OfClass(Floor).ToElements()
convert python list
collector = list(collector)
dot-net elementId list
ids = List[ElementId]([i.Id for i in collector])
transaction start
copied_elements =
copied_elements = ElementTransformUtils.CopyElements(linkdoc,ids,doc,Transform.Identity,CopyPasteOptions())
transaction done
output
OUT = copied_elements
Are you trying to copy floor instances, or floor types?
Also, just use the ToElementIds() method on the collector rather than ToElements() only to get the IDs.
I am trying to copy floor instances
Use .OfCategory(BuiltInCategory.OST_Floors). WhereElementIsNotElementType().ToElementIds() in lieu of OfClass() in the FEC.
Its not working it still throws the same error, the problem I am facing lies on this line:
copied_elements = ElementTransformUtils.CopyElements(linkdoc,collector,doc,Transform.Identity,CopyPasteOptions())
Certain Elements are not being copied and hence the whole command fails, is there a method I could use to filter out the elements that cannot be copied and the copy/paste happens for the elements that could be copied.
Try using None for the Transform.
copied_elements = ElementTransformUtils.CopyElements(linkdoc,collector,doc,None,CopyPasteOptions())
Still throw the same error.
I just tested this out, and this worked for me.
clr.AddReference('RevitAPI')
clr.AddReference('System')
LinkDoc = UnwrapElement(IN[0])
floors = FilteredElementCollector(LinkDoc[0]).OfCategory(BuiltInCategory.OST_Floors).WhereElementIsNotElementType().ToElementIds()
copied = ElementTransformUtils.CopyElements(LinkDoc[0],floors,doc,None,CopyPasteOptions())
OUT = floors,copied
I agree with you, the instances that you are trying to copy does not have any errors.
As you can read the Exception as below that I am facing:
"Exception: Copying one or more elements failed."
It does copy the elements, but it fails as a set as in some cases it may have errors.
Is there or might be way to weed out these failed elements and let the copy/paste function happen.
You could wrap it into a Try / Except block and iterate the collection one floor at a time.
for floor in floors:
	try:
		copied.append(ElementTransformUtils.CopyElements(LinkDoc[0],List[ElementId]([floor.Id]),doc,None,CopyPasteOptions()))
	except:
		copied.append("Bad Floor: " + floor.Id.ToString())
        continue
Thank you, it does work till it arrives at the bad element, and fails to continue.
File “”, line 29, in
AttributeError: ‘List[ElementId]’ object has no attribute 'append
After researching I found the script works perfectly. The issue was in Revit, I was getting the following error:
Selection cannot be copied.
Can’t Copy to Clipboard because of relationships between Elements
Hey Roshan!
I am having the same problem as you had. How did you overcome this? My case is a little different as I try to copy Views from linked file to host file.
Hi @jazlik and welcome :grinning:
please start a new topic to explain your problem,
consider adding to your message:
  • a screenshot of your dynamo graph
  • the python code
