Here is a solution under IronPython2 (with transform to node dynamo) (it’s not mine, you can imagine, look at this topic explanations by Mr. Poupin and Solution by Mr. Brendan Cassidy)
reb_b_t=UnwrapElement(IN[0])
nameT=reb_b_t.ToDSType(False).Name
OUT = nameT
cordially
christian.stan
