Converting AutoCAD.DatabaseServices.Entity to AutoCAD.DynamoNodes.Object
I’ve created feature lines in a Python Node and my results are a list of Autodesk.Civil.DatabaseServices.FeatureLine. I tried to use them to make a TIN surface but as the warning says, it needs Autodesk.AutoCAD.DynamoNodes.Object instead of Autodesk.AutoCAD.DatabaseServices.Entity.
So how can I get Autodesk.AutoCAD.DynamoNodes.Object from Autodesk.Civil.DatabaseServices.FeatureLine?
Use Featureline.GetDynamoGeometry from ArkanceSystems.
Unfortunately it expects different object than I have.
try
at picture 1
use Convert to Camber Object node
This also gives me a warning.
You can go through
Python
SurfaceDefinitionBreaklines Class
I meet the same problem.Have you solved yet?
how to convert “3“data type to “1“ or “2“?
