Friends, could you help me with this new script? I’m trying to identify elements (cad blocks) from the cad link, and convert them into corresponding families. But right at the beginning I get an error, if I use the dictionary it expects a list, if I use a list it gives an error because the names of the blocks are strings. What can I do?
This is the python that is giving error.
Update your function as follows so a single string will be enclosed in a list
def tolist(x):
if not isinstance(x , str) and hasattr(x, "__iter__"):
return x
return [x]
The Genius Loci CAD Block node is out putting the block name which is not a GeometryInstance
The GeometryInstance
element contains the information to convert
One of the nice things about custom nodes is that you can inspect the code - open up the node and the code outlines how to inspect the ImportInstance
and collect the information you want to use
I would start by copying the code and pasting into a new python node and adjust to get what you are looking for
