Convert a list of elements to a list of the names?
I hope I worded that right. I managed to get a list of parameter elements, but I cant seem to figure out how to convert that list into a list of the names of the parameters?
Have you tried the Element.Name node? Or check the parameter’s parameters for a parameter you can use GetValueByParameterName node on?
This node may be interesting: Dynamo Dictionary
Did a search for that parameter in the Library and nothing comes up. Is that a node or setting of some sort?
Got an error in that node: Warning Parameter name expects argument types (Revit.Elements.parameter) But was called with (System.Objects)
I used a Python script to get the list of parameters. Maybe I did it wrong.
Enable Python support and load DesignScript library
clr.AddReference(‘RevitAPI’)
from Autodesk.Revit.DB import*
out_list = doc.FamilyManager.GetParameters()
dataEnteringNode = IN
OUT = out_list
Maybe try the out of the box node Element.Parameters (Dynamo Dictionary) instead of the Python?
Element.Parameters won’t get you family parameters in a family doc (I think). Clockwork‘s Element.Name+ node should be able to return family parameter names. If not, Clockwork also has a node called FamilyParameter.Properties (or something like that) which definitely includes the param name.
Ah! Didn’t see this was a family document. Good catch @Andreas_Dieckmann!
That worked. Thank you!
