Containing in sheet
Hello Is it possible with Dynamo or revit to recover the surface area of ​​a volume soil and to inform them in a caption sheet or other, that is to say a printable plan containing the indicated surface.
Yes it’s possible…
How can I do it ? I need help thanks
J ai essayé mais j ai vu que seuls les paramètres d informarion du projet et les parametres partagés des feuilles peuvent être renseigné en libellés et pour les paramètres superficie je n arrive pas a les ajouter en tant que libellé
Edit Moderation : Translate
I tried but I saw that only the project information parameters and the shared parameters of the sheets can be entered as labels and for the area parameters I am unable to add them as a label
