ChatGPT is telling me I can’t constrain to a linked model using the Revit API…
Is this true?
Ask it for a link to an official indicating that is the case, and then ask it how you should go about informing the Revit team of this oversight.
Is that a yes or no?
That is an i am not sure, and you’ll either need to confirm via another source.
I tried… ![]()
I failed. ![]()
I tried to do it but failed (but that could just be me
Hence the post … Someone on here will know ![]()
I can’t seem to find any nodes in Dynamo that do this either.
Do you have nodes that allow a constraint?
Not that I can find.. Align seems to be for text, viewports, curves… not walls.
Ok - means you’re into the API or a package then. Doable. Start with aligning one item in the active model to another. Then try three items to the one. Then lists of N to t a list of M
After that look into linked model.
