Connect near Conduit connector to each other
hello every one, I want to connect near connector to each other by dynamo, I google it but i cant find a good solution for that, I only want attach these connector to each other without fitting. the direction of these connector is not important, only attach to each other, any body have an idea?
Hi @f.saeedian you could try merge ducts and pipes from genius loci seems work on conduit as well..
Revit_PAZwrKTmJs
there are a few different ways to approach this thing. in fact, one of them requires consideration of connectors’ direction.
but typically, i think u could find out the distance and direction of movement of a conduit end, creates a new location curve and apply it to the original conduit element in order to seal the gap but keep them separate.
hello @sovitek , thanks, it work for two elements that is in on direction, but not good for angle elements
not sure with that is it for Lbow-T fitting-X fitting ?
