Conduit Fitting which created is removed after running script for the second time
the dynamo script is creating fitting of conduits by using node (MEPFitting.ByMEPCurves) after do that the the fitting is don but to do the for another conduit the previous fitting is removed and create the latest fitting only
the first run script
the second run script create new fitting and removed the oldest
this the python script how can i edit on it to fix this issue?
hello @mohamed.eissaEP3P4 thats element binding, you could run from player for avoid that…or try change this line here to True…
Thank you a lot @sovitek
