Concatenating values from sublist
Hello
I would like to concatenate the values from sublists (of varying length) into a single value.
I have tried various list nodes (slice,chop,flatten)- the below is as close as I can get.
In the below example, I would like to concatenate values from sublist[0] to be “FIRE PIPEWORK, FRP”
Likewise, sublist[1] to be “HANG DOORS, FRP, SHEET WALLS, STRIP”
thank you in advance
To answer my own question:
Since the data source is an SQL database, I can create a query for the grouping/concatenation- refer below.
But if anyone has an idea to achieve the same in Dynamo, I would be interested to know how to do this.
Andrew
thank you
easy when you know how…
Andrew
Just like everything in life.
Story so far of my Dynamo life. Luckily it keeps it exciting. My approach to Dynamo is, it’s sort of a cure for cancer. I started with it at the “seek and destroy” level of data manipulation, but now I’m getting closer toward laser surgery with my scripts. About every few days I run across a new node I’ve never used and get blown away at what I can do with it!
It’s a struggle, but one with a good payoff at the end toward automation!
please package name
please package name
Are you looking for String.Join @hmidahbb? If so, this is out-of-the-box functionality :slight_smile:
The Code Block is also out-of-the-box!
i mean query node
Ah, then I’m unsure of what package that one’s from… @Andrew_Hannell do you happen to remember :smiley: ?
@hmidahbb it’s from slingshot package.
thanks a lot
