Dear All,
I have create dynamo graph to find out changes made in latest model against previous or old model.
But i am not getting desire result.
Refer attached Image herewith. Output of node ‘ModificationTracker.GeometryChanges’ is null.
I have attached here dynamo graph for your reference.
Please advice.
Thank you.
Model Comparison.dyn (52.4 KB)
You are missing an input for CurrentVersionDocument i think
Default input is a ‘Current Documents’.
I think some other things I am missing.
Thank you.
Can you try this:
Model checker - All.dyn (31.3 KB)
Thank you Marcel.
I will check with this dynamo script.
I have tried another dynamo script & it is working as I expected.
Dear All,
I have prepared another dynamo graph.
Same has been attached here for reference.
Model Comparison.dyn (32.5 KB)
M4RC3L
January 27, 2022, 7:55am
7
Marcel,
Thanks for publishing. I wonder how can I reverse all the colour coding in the model apart from setting up a new view?
M4RC3L
January 27, 2022, 8:54am
8
Hello Nilleshkatkar,
Many thanks for sharing your script.
A quick question, when I run it this happens:
I’ve been trying to replace the node with a different one, sadly, to no avail.
Kind regards,
Marcin
@M4RC3L try using the Archi-lab node.
M4RC3L
January 27, 2022, 10:03am
10
Cheers Haganjake,
Ive used Synthesize and it seems to be working:
Since I am suffering today from a fuzzy brain, coming down with something I guess, I am not sure if the script checks the current open model against the exploratory one I’ve linked.
A fresh pair of eyes would be great!
It may seem silly, just cant focus today - apologies.
It feels somehow like did something not quite right judging by the colour coded walls.
Any help much appreciated.
Marcin
