Compare lists of true/false
I’m trying to compare one list of false/true with several other lists of false/true. If they are the I would like to return a true. As you can see in the image it should give a true for the first item but is doesn’t.
Can anyone help me?
Click on the arrow besides object in the List.Equals node and check Use Levels
This is what is was looking for! thanks you!
