Hey guys,
I want to compare each element of one list (list A) to all elements of a second list (list B). and return the index of the matching in list B
example: (not a correct code of course)
for a in listA
for b in listB
if (a = b ) return index of b
I’ve tried to use " indexof " node but it doesnt work
Any help is much appreciated.
Thank you.
T_Pover
#2
You could try the node List.AllIndicesOf:
Yna_Db
#3
Hi, you could use “Equal x to y?” to compare the 2 lists, and potentially “Filter by boolean mask” if relevant:
Yna_Db
#4
… and if it doesn’t work, you can also try this node from Bakery:
Thanks a lot, it worked perfectly
the X=Y didnt work, i will try the Bakery node, Thanks a lot
