Hi everyone,
I’ve been experimenting with a workflow that combines Generative Design and Acoustic Analysis using the Space Analysis package, and I wanted to share my early results and ideas for improvement.
This workflow explores how we can automate the placement of sound barriers in a room to achieve better acoustic comfort. The sound source is a single point, and the system evaluates how different barrier configurations affect the average sound level within a specific listening area (defined by a circle around an observer).
Since I couldn’t find an existing example that merges Generative Design with the Space Analysis acoustics workflows, I thought this could serve as a good sample use case for others to explore.
Note: Make sure to download the latest version of the Space Analysis package before testing.
Setup
Define a sound source (single point).
Define one or more observers (center points for circular listening areas).
Generate an audibility grid using the Space Analysis acoustics nodes.
Generative Design Process
Randomly generate barrier geometries on a surface (in my case, I select two random point pairs to create two line-based barriers). These random selection seeds serves as my generative design inputs. You can create your own rules to decide how you would like place barriers.
Evaluate the acoustic performance for each configuration by measuring the average sound level within the observer’s circle. This serves as my output for generative design study
Run the process multiple times to explore different barrier placements using Generative Design.
Options & Variables
You can experiment with:-
Design preferences: Extremely loud → Quiet → Extremely quiet
Number of observers
Number of sound sources
Fixed vs. variable barriers
Acoustic parameters such as sound intensity and absorption (as GD input variables)
Custom rules for how and where barriers are added
The workflow calculates the average sound level within the defined diameter for each configuration, helping identify the most effective barrier positions according to user-defined comfort criteria.
This approach could evolve into an academical study that demonstrates:
How environmental simulation can inform design decisions
How Space Analysis integrates with optimization workflows
How designers can visualize and compare acoustic comfort results dynamically
This is a fun project created to demonstrate a workflow that combines acoustic calculations with Generative Design as an upskilling exercise. I also noticed that there aren’t many examples that bring these two areas together, so I hope this can serve as a starting point for anyone interested in exploring acoustic analysis and Generative Design using Dynamo.
Happy scripting!
AcousticStudy.dyn (117.7 KB)
