Hi everybody!
I’m trying to combine the values from two lists (1+2) into a third list in a certain order for placing an adaptive component between two curves. My problem is that I can’t get the right order of the points (3):
0 from list 1 with 0 from list 2
1 from list 1 with 1 from list 2
and so on …
Your issue is you are nesting your lists too deep, try cutting your two single ‘‘list.create’’ and pass the data directly to the list.create node with two inputs, what you want is two individual lists of data otherwise the list.transpose will have no effect
