Hi all,
I am trying to number the columns Left to right and top to bottom. But I would like to have the same column number based on the x, y location, as shown in the below image. I am using a script that I downloaded from this forum and trying to modify. But it is not working as desired. Any suggestions?
Col Numbering family instances sort YX.dyn (53.7 KB)
Thank you Christian.Stan
The next challenge is auto renumber when some column is deleted or added ![]()
Mr. Daan was a good teacher Create a ranking of points according to an order - #2 by Daan
(in case of addition and / or deletion by floor, it may become complicated in this case with identical numbering between floors)
cordially
christian.stan
Thanks @christian.stan. I appreciate if there are any suggestions @Daan?
