Coloring the nodes connection
Hi everyone,
I’ve been using dynamo for a few months, and in some cases i get a case that its impossible to organize the nodes without some crosses between the connection lines. That are some of then that are tens of lines crossing each other
I want to know if theres is possible to hide the lines or change the color to make better to recognize the path theyre doing via plugin or anything else
This post covers all the things you can do with wires to help organize your graph. You can pin (control placement) and hide wires but you can’t natively change their color. Iris is an extension that gives additional color controls for the nodes, but I don’t remember if it includes wire overrides as well. It should be possible through a custom extension if you wanted to go that route though.
