Collecting the perimeter curves of a Toposolid
alternative with API Revit
import sys
clr.AddReference('RevitAPI')
topo = UnwrapElement(IN[0])
slabShape = topo.GetSlabShapeEditor()
pair_vertices = [p.EndPoints  for p in slabShape.SlabShapeCreases if p.CreaseType  == SlabShapeCreaseType.Boundary]
OUT = [DS.Line.ByStartPointEndPoint(vertA.Position.ToPoint(), vertB.Position.ToPoint()) for vertA, vertB in pair_vertices]
Hi, using Position property in disguised Enumerate
pretty
cordially
christian.stan
These solutions all break if the toposolid has a curved side. The Element.Faces node breaks and unable to return a face. The element.geometry node similarly not working.
They also won’t work if any of the toposolid’s point is not elevated which is a lesser problem and can be worked around. However the curve is a trouble, my toposolids are full of curves.
Is this a limitation of the dynamo nodes or revit api? Does anyone know a workaround?
Hard to say without a dataset and knowing which version of Revit and Dynamo you are in. Can you post a simple Revit model (similar to the one above) in a new topic so we can test?
Hi Jacob,
I have opened an issue on github earlier today with all the info.
https://github.com/DynamoDS/Dynamo/issues/15241
btw this is in 2024.2 and dynamo 2.19.3 with any toposolid you sketch up with a curved side
Good to know the version, and thanks for the GitHub issue.
It would help to have an RVT posted though (here or there) as the Dynamo developers know C#, coding, and APIs fairly well, but not necessarily how to create a toposolid with a curved edge. As a result not having a sample file for stuff like this often extends the time to fix stuff by a few hours. If you get a chance to post one it would be appreciated. :slight_smile:
