Collect Room Area by Parameter name
very new to Dynamo. I’m stuck and need some assistance. I’m working on a appartment building. Every appartment has it’s own unique designation (“Bouwnummer”).
I want to add up the room area’s per appartment by using “Bouwnummer” ( every room in a unique appartment has the same "Bouwnummer"value) and return that value back into a Revit schedule ( and name it Collected Area or something like that) so that I can use that collected value for other calculations in a schedule.
I have allready have some work done but I don’t know how to finish it.
I wanted to ad the file but as a newbie I’m not allowed to!. Any comments and or pointers are appreciated.
I have used "All elements of category" and “parameter.parameterbyname” to make a list of rooms with the same “Bouwnummer”. I also have all the area values of every single room. Somehow I have to combine these two but I can’t figure out how.
“Please help me Obi-Wan Kenobi. You’re my only hope”
Thnx
ps. Tip from another user: I have added a WeTransfer link with the .dyn file
You can share your files via WeTransfer
Upload the link you receive if you wetransfer it to yourself.
Dank je. Heb ik net gedaan
Room_Area_by_Department.dyn (6.1 KB)
thnx for the feedback! But it’s not what I mean. I need to add up all the room area’s with the same “Bouwnummer” into 1 single value per “Bouwnummer”.
see image. I need to add up the area’s of all “Bouwnummers” with the same number. e.g. 001
what is that mean “Bouwnummers” ?
group and sum the values.
List.GroupByKey should work here
Room_Area_by_Department (1).dyn (15.6 KB)
Bouwnummers is a parameter that I added. It is Dutch for: building number. It is used to designate an appartement or house during the build, before they get assigned a final housenumber
And I’m so new to Dynamo that I don’t know how to group and sum but I get your point.
Thnx for your patience
I’ll try that
Thnx! Now at least I have the sum of all the rooms per appartment!
most gratefull
Goodmorning,
so I ran your script and it works. I now have all rooms belonging to a certain “Bouwnummer” added up . They are listed with random numbers. So I have no idea which summarized room area belongs to which “Bouwnummer”. Is there a way to have the Bouwnummers in the list instead off just numbers ( 0,1,2,3,4,5,etc…)?
Yes you can sort and group 1st…then make sum
:+1:
Out of curiousity; why don’t you use the Schedule to make the sums?
offcourse a very legit question. I did that first. And It shows up nicely in the schedule. The problem is that I need the calculated value of all the rooms per house/ appartment because I need to do other calculations with that area. ( e.g. The number off bike parking spaces I need to have per house based on the total area per house). I usually do it manually by making an areaplan and use that area. But by using the room area’s it’s much faster and with this Dynamo script I can use it over and over again in other projects.
List.GroupByFunction or List.GroupByKey?
In this case the number of bike parking spaces is calculated per unit, not per Area.
Am i up to date?
The municipalities determine the amount off bike parking spaces ( and also offcourse car parking spaces) based on the total area per unit. Every range off unit area’s has a minimum amount of bikes needed.
E.g. < 50m2, 3 bikes, 50m2< 65m2, 3 bikes. Etc. I have made a calculated value of this in a schedule. It works perfectly with areaplans. But if you use rooms, it looks at every room individualy, instead of the total area per unit. You can display it as a total when you uncheck “Itemize every instance”, but the schedule still looks at every instance!
So you get the wrong numbers
That’s why I was looking at Dynamo. It is also a good way to start determening the GBO via Rooms instead of Area’s.
But mayby I’m missing something in Schedules.
