Hello all,
With Dynamo & python I want to collect all walls which crossing a line. This line will be created by two points by user input. Just two clicks on the screen. I don’t want to use the Element.Geometry because that action is very slow with a large number of walls.
Can someone help me out? Thanx in advance.
clr.AddReference("ProtoGeometry")
from Autodesk.Revit.UI import TaskDialog
clr.AddReference('RevitAPI')
TaskDialog.Show("DynamoScripts", "Select two Points.")
userpoint1 = uidoc.Selection.PickPoint()
userpoint2 = uidoc.Selection.PickPoint()
line = Line.CreateBound(userpoint1, userpoint2)
coll = FilteredElementCollector(doc, doc.ActiveView.Id)
filt = ElementCategoryFilter(BuiltInCategory.OST_Walls)
walls = coll.WherePasses(filt).ToElements()
OUT = line, walls
