Can somebody tell me a way of collecting all the model lines in a project using Python?
The code below collects all lines in project which I think includes detail lines? This is too slow on a large project that has got a bit messy.
clr.AddReference('RevitAPI')
toggle = IN[0]
collector = []
if toggle == True:
collector.append(FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Lines).WhereElementIsNotElementType().ToElements())
pass
OUT = collector
Sorry, I was too fast with this. It seems not all classes in the API can be used to with the OfClass filter, where the ModelLine is one of these. Here the remark from the API:
#Import the Revit API
#Import DocumentManager and TransactionManager
#Reference the active Document and application
#---###Start scripting here:###---#
mc = FilteredElementCollector(doc).OfClass(CurveElement).ToElements()
OUT = []
for i in mc:
ct = i.CurveElementType
if ct == CurveElementType.ModelCurve:
OUT.append(ct)
OUT.append('This is a Detail Line')
