what is the python code for the below node
Hi @shibujoseukken,
You can use the ElementTransformUtils class which has a RotateElement() method as shown here…
https://www.revitapidocs.com/2020/3968f4e8-759c-f975-6c1f-7de42be633ed.htm
Here is some example code as a base which you can expand upon…
##### Imports #####
clr.AddReference("RevitAPI")
import math
##### Definitions #####
def tolist(obj1):
if hasattr(obj1,"__iter__"): return obj1
else: return [obj1]
##### Inputs #####
elems = tolist(UnwrapElement(IN[0]))
angle = tolist(UnwrapElement(IN[1]))[0]
##### Output #####
outList = []
##### Main Script #####
# Open a Transaction as we are modifying the current context Document...
for e in elems:
try:
# We are using the ElementTransformUtils class here which has a RotateElement static method. This takes a Document, ElementId, Axis of rotation as a Revit Line and the angle in radians.
# First we will create the Axis of rotation by creating an bound Revit Line from the Elements Location and the Line will be vertical so rotation is in the global XY plane...
rAxis = Line.CreateBound(e.Location.Point, XYZ(e.Location.Point.X,e.Location.Point.Y,e.Location.Point.Z+1))
# We then do the rotation. The method returns Void (returns nothing)...
ElementTransformUtils.RotateElement(doc,e.Id,rAxis, math.radians(angle))
# Report if this was successful...
outList.append("Success")
# Catch and report Exception...
except Exception,ex:
outList.append(ex.message)
# We are done so close the Transaction...
# Return results to Dynamo Workspace...
OUT = outList
Cheers,
Dan
