what it the right syntax to get simple list with the same amount of levels? Example below. Cheers,
If you want a list with an unique level :
0..5; is sufficient.
If you want a nested list :
{{0,1,2,3,4,5}};
You can always use DSCore.List.Flatten Node, and set it to correct level and amount.
You’re adding an extra level that you may not need.
In pre 2.x format: {1..3,{1,2,3}};
In 2.x format: ‘[1…3,[1,2,3]];’
The design script range n..m automatically generates the result as a 2d list, so those numbers don’t need to be in the wrappers.
Great! Many Thanks.
