Hi everybody,
sorry for my terrible programming skills…I try to write the Code Block node but I have the following two problems…
Thank you in advance for the help !
Antonio
Drop the code here.
clr.AddReference(‘RevitNodes’)
clr.AddReference(‘RevitAPI’)
memb = MaterialFunctionAssignment.Membrane
fin1 = MaterialFunctionAssignment.Finish1
fin2 = MaterialFunctionAssignment.Finish2
types = UnwrapElement(IN[0])
f2m = IN[1]
for t in types:
cs = t.GetCompoundStructure()
last_layer = cs.LayerCount - 1
for i in (0 , last_layer):
cur_fn = cs.GetLayerFunction(i)
if f2m and (cur_fn == fin1 or cur_fn == fin2):
cs.SetLayerFunction(i, memb)
# membranes require a thickness of 0
cs.SetLayerWidth(i, 0.0)
elif not f2m and cur_fn == memb:
cs.SetLayerFunction(i, fin1)
# finish layers need some width
# you’ll need to determine those yourself
cs.SetLayerWidth(i, 0.1)
t.SetCompoundStructure(cs)
OUT = 0
@fablabolbia Like this.
You can copy paste this code.
f2m = IN[1]
for t in types:
OUT = 0
No problem Mark the post as solved.
Done !
Thank you again
good afternoon!
I have a similar problem. Could suggest …
import clr, System
doc = DocumentManager.Instance.CurrentDBDocumentnameOfCategory = “Space”
bui = System.Enum.GetValues(BuiltInCategory) # Все BuiltInCategory
cats, buis = ,
for i in bui:
try:
cat = Revit.Elements.Category.ById(ElementId(i).IntegerValue) # Имена всех категорий
cats.append(cat)
buis.append(i)
except:
passfor i, b in zip(cats, buis):
if nameOfCategory == str(i): # Если имена категорий совпадают
ost = b # то получаем его BuiltInOUT = FilteredElementCollector(doc).OfCategory(ost).WhereElementIsNotElementType().ToElements()
