Hi all,
I was playing around with some indexing of a list with a nested list, pulling index 2 from each nested list. In my pursuit of doing this inside a code block I ran across this thread:
http://dynamobim.org/forums/topic/code-blocks-and-lacing/
in the second post Dimitar refers to ‘replication’ which I assume is a different name for lacing, maybe?
I read up on ‘replication’ and sort of understand but need more hands on to fully grasp the idea.
but my main question is, following the example in the link I have (lst<1>,2) and (lst<2>,2) the number in <#> gives the same results. Why?
From my experience :
The numbers into brackets refer to lacing, but also refer to one another.
a<1>, b<2> indicates cross-lacing between a and b, a being the principal component.
a<1>, b<1> indicates auto-lacing between a and b.
a<1L>, b<1L> indicates longest-lacing between a and b
a<1l>, b<1l> indicates shortest-lacing between a and b. (not 100% sure)
If you indicate only a single bracket, i the function would be set to auto-lacing automaticcaly because the bracket cannot refer to anything.
Note : a<1>,b<2> produces the same result as a<1>,b<3> or a<2>,b<3>
Also, in your example, there is no second list to proceed to cross-lacing.
The original example appears to be more of a list @ level function than a lacing function.
Thanks for the reply guys, I found something that helped me out.
DesignScript Syntax
Scroll down to How About Lacing?
What I found and linked didn’t answer my question out right but with your replies, I’m guessing that I am more level filtering than lacing in my example above?
This is the site I originaly read about Replication
Replication
