clr.AddReference('DSCoreNodes')
from DSCore import *
from Revit.Elements import *
clr.AddReference('System')
clr.AddReference('RevitAPI')
app = uiapp.Application
dataEnteringNode = IN
scheduleField = UnwrapElement(IN[0])
for i in scheduleField:
Field = i.IsHidden
OUT = Field
Hi guys,
How to check if the schedule field IsHidden?
Got it
keyschedule = UnwrapElement(IN[0])
definition = keyschedule.Definition
ids = definition.GetFieldOrder()
names = []
hidden = []
for id in ids:
param = definition.GetField(id)
names.append(param.GetName())
hidden.append(param.IsHidden)
OUT = hidden
Thank you @interactiverendering I know very little Python. When I created a node for this I got some indentation errors. It took me a little while to figure out how to fix it.
Putting it here in case there are any others out there that need to find hidden fields in a table and are horrible with Python like me.
definition = schedule.Definition
names = []
hidden = []
for id in ids:
OUT = hidden
Hey! Thanks a lot for your examples. The only problem with the script is that in can only take a single schedule as an input, giving out an if you try working with a list of schedules. However, it seem that I’ve managed to solve this issue.
(I’ve just started earning Python so the code might be not optimal…)
schedules = UnwrapElement(IN[0])
ls = []
for n in range(len(schedules)):
schedule = schedules[n]
param = []
for id in ids:
param.append(definition.GetField(id))
hidden = []
names = []
for p in param:
names.append(p.GetName())
hidden.append(p.IsHidden)
ls.append(hidden)
OUT = ls
