Changing Parameter Values of Different Elements in Dynamo via Excel
Hello, I have a system like the one in the image.
My purpose: I have my element names and their new values ​​in Excel. I want to call these values ​​in Dynamo and paste them in place of the old values.
However, it does not recognize Element names. What do you think I should do?
Hi @sefa i think you should try feed in element instead of strings
But my data is in excel @sovitek
yes but you will need pair these names up with elements, i assume these elements alreaydy exist in the model…
Yes they are available with the same name
I can also use “Family Name” instead of the element name. Will the same thing happen?
yes it will, try collect your families you wanna pair up with and get its names and then use all indicies of for get the elements
Can you share an example?
something here maybe…
here for element type in that case these elements isnt are placed yet, but are in the model[projectbrowser only] then you can write to a type parameter
