Trying to see if anyone has any info if this is possible. I’ve tried looking but couldn’t find if there are any nodes/code that would allow you to change the Loaded Tags in the project for certain categories. The aim is to switch between two different families across the categories without having to manually select it for each type. Is this possible?
hi @ppittas
As far as I know, the thing you are trying to do is still not possible as the API of Revit for Default Tags are not yet available. I am also trying to do this to make 2D drawing very easy (easily change the settings when switching from section view to plan view and vice versa).
You can check Revit API here:
https://www.revitapidocs.com/2021.1/
-biboy
