Please, could you advise if there is a way to convert the date/time format imported from excel into dynamo to a different format? as follows:
current format: February 08, 2017, 04:47PM
required format: 2018-02-08T16:47 (to suit COBie time format)
Many Thanks
Using OOTB date nodes:
You need to specify the output format following a particular notation that can be found at “Custom Date and Time Format Strings”
alvpickmans
Many Thanks for the response, I can’t seem to find the DateTime.Format Node?
I am using revit 2016 and dynamo 1.2.
I believe it was released on Dynamo version 1.3
Kulkul
5
Hi @davebull1979
Try this:
Copy paste this in code block:
dt=DSCore.DateTime.Components(dt1);
dt2=dt["year"]+"/"+dt["month"]+"/"+dt["day"]+"T"+dt["hour"]+":"+dt["minute"];
Just updated to latest dynamo release and it is now available
Many Thanks.
Kulkul
8
@davebull1979 Please mark the post as solved. You’re welcome!
Kulkul
9
@davebull1979 @alvpickmans And here is python magic
