Change models in dynamo
The action in this video describes what I want to automate using Dynamo.
Does anyone know if this is possible?
To get answer quickly, I suggest you to check out our forum [guidelines] (How to get help on the Dynamo forums).
Is it possible for you to share what you have tried until now?
hi @giel.lambrechts i’m sure you’ll go through the guidelines as mentioned by @emrullah.yildiz
still here’s a pretty basic example of what u trying to do i feel
Hope it helps
Regards,
BM
Thanks for your help
I found a solution for my problem with some dynamo code and python scripts.
I found my solution. but still , Thank you for taking the time to answer.
