Does anyone know how i can change te a group name with Dynamo.
I used the elemen.setparameterbyname node with “Type Name” as parameterName
no success.
Parameter Read only error???
What does the error say?
I should’ve read that in your original comment.
But errr, I guess you can’t do it with node.
There’s the Element.SetName node from the Clockwork package which should do the job for you.
Good to hear.
If a comment solved your issue please mark it as solved so others with a similar issue might find it easier to solve their problem (and maybe leave somewhere).
